D365 Report printing error
All,
Im trying to print OOB SSR report in my Local DEV D365 8.0 PU15 env,. Im getting below error . Report config manager is fine and able to see reports in web portal and able to prin too. But when i print it in D365FO it errors below
Microsoft.Reporting.WebForms.ReportServerException
stackTrace Microsoft.Reporting.WebForms.ReportServerException: An error has occurred during report processing. (rsProcessingAborted) ---> Microsoft.Reporting.WebForms.ReportServerException: Query execution failed for dataset 'CustListReportDS'. (rsErrorExecutingCommand) ---> Microsoft.Reporting.WebForms.ReportServerException: Exception occurred on the metadata service on client or server. See exception details below: >An error occurred while making the HTTP request to usnconeboxax1aos.cloud.onebox.dynamics.com/.../. This could be due to the fact that the server certificate is not configured properly with HTTP.SYS in the HTTPS case. This could also be caused by a mismatch of the security binding between the client and the server. ---> Microsoft.Reporting.WebForms.ReportServerException: An error occurred while making the HTTP request to usnconeboxax1aos.cloud.onebox.dynamics.com/.../. This could be due to the fact that the server certificate is not configured properly with HTTP.SYS in the HTTPS case. This could also be caused by a mismatch of the security binding between the client and the server. ---> Microsoft.Reporting.WebForms.ReportServerException: The underlying connection was closed: An unexpected error occurred on a send. ---> Microsoft.Reporting.WebForms.ReportServerException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. ---> Microsoft.Reporting.WebForms.ReportServerException: An existing connection was forcibly closed by the remote host --- End of inner exception stack trace --- --- End of inner exception stack trace --- --- End of inner exception stack trace --- --- End of inner exception stack trace --- --- End of inner exception stack trace --- --- End of inner exception stack trace --- at Microsoft.Reporting.WebForms.SoapReportExecutionService.ServerUrlRequest(AbortState abortState, String url, Stream outputStream, String& mimeType, String& fileNameExtension) at Microsoft.Reporting.WebForms.ServerReport.InternalRender(Boolean isAbortable, String format, String deviceInfo, NameValueCollection urlAccessParameters, Stream reportStream, String& mimeType, String& fileNameExtension) at Microsoft.Reporting.WebForms.ServerReport.Render(String format, String deviceInfo, NameValueCollection urlAccessParameters, String& mimeType, String& fileNameExtension) at Microsoft.Reporting.WebForms.ServerModeSession.RenderReport(String format, Boolean allowInternalRenderers, String deviceInfo, NameValueCollection additionalParams, Boolean cacheSecondaryStreamsForHtml, String& mimeType, String& fileExtension) at Microsoft.ReportingServices.Rendering.HtmlRenderer.ViewerRenderer.SPBProcessingStub.GetNextPage(RPLReport& rplReport) at Microsoft.ReportingServices.Rendering.HtmlRenderer.HTML4Renderer.GetNextPage() at Microsoft.ReportingServices.Rendering.HtmlRenderer.HTML4Renderer.InitializeReport() at Microsoft.ReportingServices.Rendering.HtmlRenderer.ViewerRenderer.Render(HtmlTextWriter outputWriter) at Microsoft.Reporting.WebForms.LocalHtmlRenderer.Render(NameValueCollection deviceInfo, PageCountMode pageCountMode, ReportControlSession reportControlSession, CreateAndRegisterStream streamCallback, String& scrollScript, String& pageStyle) at Microsoft.Reporting.WebForms.ReportControlSession.RenderReportHTML4(NameValueCollection deviceInfo, PageCountMode pageCountMode, String& scrollScript, String& pageStyle) at Microsoft.Reporting.WebForms.ReportControl.RenderReport(ReportControlSession session, String viewerInstanceIdentifier, PageCountMode pageCountMode, Int32 pageNumber, InteractivityPostBackMode interactivityMode, SearchState searchState, String replacementRoot, String hyperlinkTarget, ScrollTarget scrollTarget, String alertMessage, DeviceInfoCollection initialDeviceInfos, String browserMode, Boolean sizeToContent) at Microsoft.Reporting.WebForms.ReportArea.RenderReport(ReportControlSession session, String viewerInstanceIdentifier, PageCountMode pageCountMode, Int32 pageNumber, InteractivityPostBackMode interactivityMode, SearchState searchState, String replacementRoot, String hyperlinkTarget, ScrollTarget scrollTarget, String alertMessage, DeviceInfoCollection initialDeviceInfos, String browserMode, Boolean sizeToContent) at Microsoft.Reporting.WebForms.ReportViewer.RenderReport(Boolean updateDocMap) at Microsoft.Reporting.WebForms.ReportViewer.OnPreRender(EventArgs e)
Related
Recommended
