Error While Creating Return Order Using AIF.
Hi, All.
I am trying to create a return order in AX using AIF, but it fails with the below error.
The request failed with the following error:
The message with Action 'schemas.microsoft.com/.../create' cannot be processed at the receiver, due to a ContractFilter mismatch at the EndpointDispatcher. This may be because of either a contract mismatch (mismatched Actions between sender and receiver) or a binding/security mismatch between the sender and the receiver.  Check that sender and receiver have the same contract and the same binding (including security requirements, e.g. Message, Transport, None).
Steps I have Followed so far.
1. reactivated the inbound port
2. perform the incremental CIL.
3. And then deployed the service group.
Still, the issue persists. Looking for a solution anyone please suggest a way to fix this.
Note: AX version in 2012 FPK.
Thanks in Advance,
Thomas.
Related
Recommended
