Journal name *****. does not support journal type Daily.
i had to filter Payment journal on the bases of created date and time, for that i used this line of code in execute query() of data source inventjournaltable
this.query().dataSourceName(LedgerJournalTable_ds.name()).addRange(fieldnum(LedgerJournalTable, CreatedDateTime)).value(SysQuery::range(roletable.uptodate,dateMax()));
the records got filtered as per my requirement  but i am facing an other problem that is when creating new journal i am facing an error
Journal name BVHO. does not support journal type Daily.
 by default journal type is Daily but for payment journal i want Payment but due to my customization ledger type is not changing to required type
so i need help regarding this issue that what should i do next so that my filter also work and other things also work normally.
waiting for a quick response.
  • Add this code in the active method of data source Table
    if(element.args().menuItemName() == menuitemdisplaystr('LedgerJournalTable5'))  {  LedgerJournalTable.JournalType=LedgerJournalType::Payment;  }
    else if(element.args().menuItemName() == menuitemdisplaystr('LedgerJournalTable_CustPaym'))  {  LedgerJournalTable.JournalType=LedgerJournalType::CustPayment;  }  else if(element.args().menuItemName() == menuitemdisplaystr('LedgerJournalTable9'))  {  LedgerJournalTable.JournalType=LedgerJournalType::VendInvoiceRegister;  }
    else if(element.args().menuItemName() == menuitemdisplaystr('LedgerJournalTableAssets'))  {  LedgerJournalTable.JournalType=LedgerJournalType::Assets;  }
Related
Recommended
