Need to show all production id's when filter is removed
Hi all
I'm trying to filter the records based on Production id, when I give production id stringedit text box form is getting filtered based on the record I'm entering at the same time when i remove the production id it need to show entire production id
public boolean modified()
    boolean ret;
    ret = super();
    breakpoint;
    if (this.valueStr()!="")
    ProdTable_ds.query().dataSourceTable(tablenum(ProdTable)).clearDynalinks();
    ProdTable_ds.query().dataSourceTable(tablenum(ProdTable)).clearRange(fieldnum(ProdTable, ProdId));
    ProdTable_ds.query().dataSourceTable(tablenum(ProdTable)).addRange(fieldnum(ProdTable, ProdId)).value(queryValue(this.text()));
    ProdTable_ds.executeQuery();
    else
    ProdTable_ds.query().dataSourceTable(tablenum(ProdTable)).addRange(fieldnum(ProdTable,ProdId)).value(queryValue(SysQuery::valueUnlimited()));
    return ret;
May I know how to do this?
  • public void executeQuery()
        QueryBuildRange prodidfilter,itemidfilter,statusfilter,sitefilter;;
        prodidfilter = SysQuery::findOrCreateRange(ProdTable_q.datasourceTable(tableNum(ProdTable)),fieldNum(ProdTable,ProdId));
        itemidfilter= SysQuery::findOrCreateRange(ProdTable_q.datasourceTable(tableNum(ProdTable)),fieldNum(ProdTable,ItemId));
        statusfilter= SysQuery::findOrCreateRange(ProdTable_q.datasourceTable(tableNum(ProdTable)),fieldNum(ProdTable,ProdStatus));
        sitefilter = SysQuery::findOrCreateRange(ProdTable_q.datasourceTable(tableNum(InventDim)),fieldNum(InventDim, InventSiteId));
        if (txtProdId.text()!="")
            prodidfilter.value(queryValue(txtProdId.text()));
        else
            prodidfilter.value(SysQuery::valueUnlimited());
        if (txtItemid.text()!="")
            itemidfilter.value(queryValue(txtItemid.text()));
        else
            itemidfilter.value(SysQuery::valueUnlimited());
        if (txtProdStatus.text()!="")
            statusfilter.value(queryValue(txtProdStatus.text()));
        else
            statusfilter.value(SysQuery::valueUnlimited());
         if (txtsite.text()!="")
            sitefilter.value(queryValue(txtsite.text()));
        else
            sitefilter.value(SysQuery::valueUnlimited());
        super();
        boolean ret;
        ret = super();
        return ret;
    Done Like this:)
Related
Recommended
