Inquiring the Name of a Job
I have developed a job which updates several fields in a table. This table has a comment field and as part of the update I'd like to insert the name of the job being run. So that I dont have to hard-code the job name in my code, is there a means of querying the job name?
Without including the full job, this is a sample bit of code which should help explain
static void myJob(Args _args)
    str myJobName = ??????
    info(strFmt("The name of this job is: %1", myJobName));
The expected output would be;
The name of this job is: myJob
Any help with this would be greatly appreciated
TIA, Paul
Related
Recommended
