Update statement in job
Hi
I have SQL updates which has to be written in X++ .
--Update Inventory Item Name ------------------------------------------------------------------
Update #P0000 set #P0000.Txt = Name
from #P0000, InventTable, EcoResProductTranslation ERPT where
InventTable.Product = ERPT.Product and
#P0000.EmplItemId = InventTable.ItemId and InventTable.DataAreaId = @Entity and
ProjTransType = 4
--Update Employee Name ------------------------------------------------------------------------
Update #P0000 set #P0000.Txt = HWCD.Name, EmplItemId = PersonnelNumber
from #P0000, HcmWorkerCubeDimension HWCD where
#P0000.Worker = HWCD.RecId and --HWCD.DataAreaId = @Entity and
ProjTransType = 2
I wrote a job as follows:
while select * from _ecoresproductranslation join product from _inventtable
join EmplItemId from caeprojtransposting
where _ecoresproductranslation.Product == _inventtable.Product && _inventtable.ItemId ==
 caeprojtransposting.EmplItemId && caeprojtransposting.ProjTransType == 4
while select forupdate caeprojtransposting join ItemId from _inventtable where _inventtable.ItemId ==
 caeprojtransposting.EmplItemId && caeprojtransposting.ProjTransType == 4 && caeprojtransposting.Txt ==''
ttsBegin;
caeprojtransposting.Txt = _ecoresproductranslation.Name;
caeprojtransposting.update();
ttsCommit;
//Update Employee Name
ttsBegin;
while select forupdate caeprojtransposting join RecId from _HcmWorkerCubeDimension where _HcmWorkerCubeDimension.RecId ==
caeprojtransposting.Worker && caeprojtransposting.Txt=='' && caeprojtransposting.Worker != 0 && caeprojtransposting.ProjTransType == 2
caeprojtransposting.Txt = _HcmWorkerCubeDimension.Name;
caeprojtransposting.EmplItemId = _HcmWorkerCubeDimension.PersonnelNumber;
ttsCommit
First update works but the second update doesn't works. I am not sure whether the above code is correct.;
Related
Recommended
