Multi select Lookup in dialog class using Enum Field in ax 2012
I have 2 multiselect dialog field in which both are enums, when I select multiple values from the lookup the values displayed in the dialogfield control is 0;1 .. etc instead of this I want to display the enum label in the test box how to achieve this in dialog class in ax 2012. Please suggest an answer.
Thanks in advance,
Gopinath M.
Related
Recommended
