Adding display method to an extension form datasource
i want to add a display method on an extended form datasource.
The form i extended is LedgerJournalTransAsset, the datasource i want to add a new method to is LedgerJournalTrans.
I created the extension with the folowing code:
[ExtensionOf(formStr(LedgerJournalTransAsset))]
final class LedgerJournalTransAsset_Extension
     /// how to add a display method under a datasource context here?
     /// or will any method added here belong to Form element?
Probably for performance reasons the standard approach uses the LedgerJournalEngine class where a LedgerJournalTable buffer is already loaded, that's why i am not adding my new method to LedgerJournalTrans directly.
any help is appreciated.
Related
Recommended
