Excel import and export
I'm trying to insert and activate an item with price from excel and when the item from the excel is not present in the item table i need to export the items into excel from ax..
Here is my code importing is fine but exporting is not happening..
void clicked()
    SysExcelApplication             application,app1;
    SysExcelWorkbooks               workbooks,wbooks;
    SysExcelWorkbook                workbook,wbook;
    SysExcelWorksheets              worksheets,wsheets;
    SysExcelWorksheet               worksheet,wsheet;
    SysExcelCells                   cells,cells1;
    SysExcelCell                    cell;
    COMVariantType                  type;
    System.DateTime                 ShlefDate;
    FilenameOpen                    filename;
    dialogField                     dialogFilename;
    Dialog                          dialog;
    //Table Declarations Starts
    InventItemPrice                 inventprice;
    InventDim                       _inventdim;
    InventParameters                inp;
    InventTableModule               inm,inventTableModule;
    InventItemPriceSim              iips,inventItemPriceSimulated;
    InventTable                     _inventtable;
    //Table Declartions Ends
    //field declaration
    ItemId                          _itemid;
    CostingVersionId                _versionid;
    CostingVersionPriceType         _type;
    Price                           _price;
    PriceUnit                       _unit;
    CostingVersionId                _version;
    InventDimId                     _invent;
    InventSiteId                    _site;
    TransDate                       _fromdate;
    InventItemCostingType           _costingType;
    int                             row,row1;
    #OCCRetryCount
    #Excel
    // convert into str from excel cell value
    str COMVariant2Str(COMVariant _cv, int _decimals = 0, int _characters = 0, int _separator1 = 0, int _separator2 = 0)
    switch (_cv.variantType())
    case (COMVariantType::VT_BSTR):
    return _cv.bStr();
    case (COMVariantType::VT_R4):
    return num2str(_cv.float(),_characters,_decimals,_separator1,_separator2);
    case (COMVariantType::VT_R8):
    return num2str(_cv.double(),_characters,_decimals,_separator1,_separator2);
    case (COMVariantType::VT_DECIMAL):
    return num2str(_cv.decimal(),_characters,_decimals,_separator1,_separator2);
    case (COMVariantType::VT_DATE):
    return date2str(_cv.date(),123,2,1,2,1,4);
    case (COMVariantType::VT_EMPTY):
    return "";
    default:
    throw error(strfmt("@SYS26908", _cv.variantType()));
    return "";
    dialog              =   new Dialog("Excel Upoad");
    dialogFilename      =   dialog.addField(typeId(FilenameOpen));
    dialog.filenameLookupTitle("Upload from Excel");
    dialog.caption("Sales Price Excel Upload");
    dialogFilename.value(filename);
    if(!dialog.run())
    return;
    filename            =   dialogFilename.value();
    application         =   SysExcelApplication::construct();
    workbooks           =   application.workbooks();
    try
        workbooks.open(filename);
    catch (Exception::Error)
        throw error("File cannot be opened.");
    workbook            =   workbooks.item(1);
    worksheets          =   workbook.worksheets();
    worksheet           =   worksheets.itemFromNum(1);
    cells               =   worksheet.cells();
    try
    ttsbegin;
    do
        row++;
        _itemid           =   COMVariant2Str(cells.item(row, 1).value());
        _price            =   cells.item(row, 2).value().double();
        _site             =   COMVariant2Str(cells.item(row, 3).value());
        select Costingversionid from inp;
        _versionid=inp.Costingversionid;
        breakpoint;
        if(row > 1)
            select firstonly iips;
            if(iips.ItemId==_itemid)
                    iips.ItemId=_itemid;
                    iips.VersionId=_versionid;
                    iips.PriceType=CostingVersionPriceType::Sales;
                    _inventdim.InventSiteId=_site;
                    iips.InventDimId=InventDim::findOrCreate(_inventdim).inventDimId;
                    iips.Price=_price;
                    iips.PriceUnit=1;
                    iips.FromDate=systemdateget();
                    iips.insert();
                    InventItemPriceActivationJob::activateInventItemPriceSimExt(iips);
                    info(strfmt("Items inserted successfully for %1",iips.ItemId));
          else
                info(strfmt(" Items not inserted for %1",_itemid));
                app1 = SysExcelApplication::construct();
                wbooks = app1.workbooks(); //gets the workbook object
                wbook = workbooks.add();  // creates a new workbook
                wsheets = workbook.worksheets(); //gets the worksheets object
                wsheet = worksheets.itemFromNum(1);//Selects the first worksheet in the workbook to insert data
                cells1 = worksheet.cells();
                cells1.range('A:A').numberFormat('@');
                cell=cells1.item(row,1);
                cell.value(_itemid);
                cell=cells1.item(row,2);
                cell.value(_price);
                cell=cells1.item(row,3);
                cell.value(_site);
                app1.visible(true);
        type = cells.item(row+1, 1).value().variantType();
        }while (type != COMVariantType::VT_EMPTY);
        application.quit();
        ttscommit;
        catch
            Error("Upload Failed");
How could i export the error items ?
thanks
Related
Recommended
