Post multiple lines of Inventory adjustment journal via code
Hi there ,
I am able to post one line in journal but when there multiple lines in the journal, I am unable to post
Please HELP
static void Posting3(Args _args)
         InventJournalTable inventJournalTable;
         InventJournalTrans inventJournalTrans;
         InventJournalNameId inventJournalName;
         InventDim inventDim;
         InventJournalId inventJournalId;
        JournalCheckPost journalCheckPost;
       //Below code creates journal header
       inventJournalTable.clear();
       inventJournalName = 'IPL';
       inventJournalTable.initFromInventJournalName(InventJournalName::find(inventJournalName));
       inventJournalTable.insert();
       //Below code creates journal lines
       while select * from inventJournalTable
       where inventJournalTable.Posted == 0 &&
       inventJournalTable.NumOfLines!=0
       if(inventJournalTable.RecId)
           inventJournalId = inventJournalTable.JournalId;
           inventJournalTrans.clear();
           inventJournalTrans.initFromInventJournalTable(inventJournalTable);
           inventJournalTrans.TransDate = systemDateGet();
           select firstOnly * from inventJournalTrans
           where inventjournaltrans.JournalId == inventJournalId;
           inventJournalTrans.ItemId = inventJournalTrans.ItemId;
           inventJournalTrans.initFromInventTable(InventTable::find(inventJournalTrans.ItemId));
           inventJournalTrans.Qty = inventJournalTrans.Qty;
           inventDim.InventSiteId = 'XXX';
           inventDim.InventLocationId = 'XXX';
           inventJournalTrans.InventDimId = inventDim::findOrCreate(inventDim).inventDimId;
           inventJournalTrans.Voucher = 'XXXX';
           inventJournalTrans.insert();
//The below code posts the journal
journalCheckPost = InventJournalCheckPost::newPostJournal(inventJournalTable);
journalCheckPost.run();
Related
Recommended
