Hello,
i need to fully unreserve quantity against prodline with specified WMSLocationId
this is the code i use, it doesnt work, maybe somebody see why ?
ttsBegin;
while select * from newProdBOM where newProdBOM.ProdId == lProdTable.ProdId { inventMovement = InventMovement::construct(newProdBOM, InventMovSubType::None); inventDimTable = InventDim::find(newProdBOM.InventDimId); inventDimTable.wMSLocationId = ProdParameters::find().INSWMSLocationId;
inventDimTable = InventDim::findOrCreate(inventDimTable); inventUpd_Reservation = InventUpd_Reservation::newInventDim(inventMovement,inventDimTable, 0, true); inventUpd_Reservation.updatenow(); } ttsCommit;
Out of a functional interest, why do you want to do this?
Well cant tell, just the FDD asks so :)
figured it out already, quantity had to be max int number
Not sure what I can say to that. Give them what is documented and hope it does not mess up standard processing setting changes or cause then more problems!
Raimondas said:nventUpd_Reservation = InventUpd_Reservation::newInventDim(inventMovement,inventDimTable, 0, true);
Have you tried by setting the opposite sign on quantity? (negative quantity)
