Field is missing from the returned result set
Exception Message :The dataset ‘SalesInvoiceDS’ contains a definition for the Field ‘GiroType’. This field is missing from the returned result set from the data source.
[moved from title by moderator]
 I try to debug the below method Underlined line shows the warning.
SRSReportRunPrinter - Class
Method:
private Array renderReportToFile(Filename _filename, SRSReportFileFormat _fileFormat)
Array files = this.parmSrsProxy().renderReportToFile(reportContract.parmReportPath(),
reportParamArray,
_filename,
_fileFormat,
printSettings.deviceInfo());
// write warnings to log.
this.displayReportErrors(); ----------- Error Warning Rised here ----------
return files;
Then I Step into that method it calls  SrsProxy  class the below method. you can see the underlined line
public Array getReportWarnings()
Array reportWarnings = new Array(Types::String);
System.Collections.ArrayList warnings;
System.Collections.IEnumerator enumerator;
anytype warning;
try
reportingServicesExecutionInfo = reportingServicesProxy.get_ReportExecutionInfo();--Error Raised--
if (reportingServicesExecutionInfo != null)
warnings = reportingServicesExecutionInfo.get_ReportWarnings();
if (warnings != null)
enumerator = warnings.GetEnumerator();
while (enumerator.MoveNext())
// BP deviation documented
warning = CLRInterop::getAnyTypeForObject(enumerator.get_Current());
reportWarnings.value(reportWarnings.lastIndex() + 1, any2str(warning));
catch (Exception::CLRError)
// We must trap CLRError explicitly, to be able to retrieve the CLR exception later (using CLRInterop::getLastException() )
SRSProxy::handleClrException(Exception::Error);
return reportWarnings;
In this method "reportingServicesProxy.get_ReportExecutionInfo()" .The  reportingservicesproxy buffer is initialized in the  SysProxy  class
Microsoft.Dynamics.AX.Framework.Reporting.Shared.Proxy     reportingServicesProxy;
But it is a framework.How can I debug this? Please, anyone gives suggestions to come out of this.
Lakshmikanthan K
Related
Recommended
