i tested by using 1 journal that have 2 invoices.however, it will give output as 2 invoice but second invoice is same information with first invoice. i know my looping is wrong but i dont know how to fix it already. i use debugger, it loop at the underline code below,but when it loop for second invoice, it not return the correct value as it only copy the first invoice value.
protected container outputPaymAdvice(VendOutPaymRecord   _clsVendOutPaymRecord, container gconRecord)
   #define.space(' ')
   VendPaymModeTable       tblPaymMode;
   LedgerJournalTable     tblLedgerJournalTable;
   LedgerJournalTrans     tblLedgerJournalTrans;
   VendTrans               vendTrans;
   str                    strRecord;
   str                     strFileRef;
   BankAccountTable       tblBank;
   SpecTrans               tblSpecTrans,tblSpecTransCheck;
   str     strFileName = "";
   tblPaymMode = VendPaymModeTable::find(_clsVendOutPaymRecord.parmCustVendPaym().ledgerJournalTrans().PaymMode);
   tblBank = _clsVendOutPaymRecord.parmCustVendPaym().bankAccountTable();
   tblLedgerJournalTrans = _clsVendOutPaymRecord.parmCustVendPaym().ledgerJournalTrans();
   select tblSpecTransCheck
       where tblSpecTransCheck.SpecTableId == tblLedgerJournalTrans.TableId &&
             tblSpecTransCheck.SpecRecId == tblLedgerJournalTrans.RecId &&
             tblSpecTransCheck.SpecCompany == tblLedgerJournalTrans.Company;
   if(tblSpecTransCheck)
       while select tblSpecTrans
       where tblSpecTrans.SpecTableId == tblLedgerJournalTrans.TableId &&
             tblSpecTrans.SpecRecId == tblLedgerJournalTrans.RecId &&
             if (tblSpecTrans.vendTrans().Invoice)//for Payment Advice fix format
                   //1:   RECORD TYPE. Format: 9(1)   Range: 1-1     Mandatory: Y Remark : Payment Advice fix format
                   strRecord += strLFix("3", 1) ;
                   //2:   Spacing Line.   Format: X(20). Range: 2-4. Mandatory: Y.
                   strRecord += strupr(strrep(#space,2));
                   //3:   Invoice no.   Format: x(20). Range: 4-24. Mandatory: Y.
                   strRecord += strLFix(tblSpecTrans.vendTrans().Invoice, 20);
                   //4:    Invoice Date.   Format: 9(8). Range: 24-32. Mandatory: N.
                   strRecord += SKMY_BankIntgrUtilUOB_ANT::convertDate2str(tblSpecTrans.vendTrans().TransDate);
                   //5:   Invoice Amount.   Format: 9(9)V9(2). Range: 32-43. Mandatory: N.
                   strRecord += SKMY_BankIntgrUtilUOB_ANT::real2NumChar(-tblSpecTrans.Balance01, 11, true);
                   //6:   Gross Amount.   Format: 9(9)V9(2). Range: 43-20. Mandatory: N.
                   strRecord += strupr(strrep(#space,11));
                   //7:   Discount.   Format: 9(9)V9(2). Range: 54-20. Mandatory: N.
                   strRecord += strupr(strrep(#space,4));
                   //8:   Positive or Negetive sign.   Format: x(1). Range: 58-59. Mandatory: Y.
                     if (-tblSpecTrans.Balance01 >= 0)
                       strRecord += strLFix("+", 1);
                     else if (-tblSpecTrans.Balance01 < 0)
                       strRecord += strLFix("-", 1);
                     //9:   Item code.   Format: x(30). Range: 59-89. Mandatory: N.
                   strRecord += strupr(strrep(#space,30));
                 //10:   Item description line 1.     Format: x(35). Range: 89-124. Mandatory: N.
                   strRecord += strupr(strrep(#space,35));
                   //11:   Item description line 2.     Format: x(35). Range: 124-159. Mandatory:N.
                   //12:   Item description line 3.     Format: x(35). Range: 159-194. Mandatory: N.
                   //13:   Filler   Format: x(1609). Range: 194-1609. Mandatory: Blanks
                   //strRecord += strupr(strrep(#space,1609));
                   gconRecord = conins(gconRecord, conlen(gconRecord) + 1, strRecord);
   else
       //1:   RECORD TYPE. Format: x(1)   Range: 1-2     Mandatory: Y Remark : Payment Advice Freetext
       strRecord = strLFix("4", 1) ;
       //2:   Spacing Line.   Format: 9(2). Range: 2-4. Mandatory: Y.
       //3:   Payment Advice Details.   Format: x(105). Range: 4-109. Mandatory: Y.
       strRecord += strLFix(tblLedgerJournalTrans.txt, 105);
       //4:   Filler   Format: x(1694). Range: 109-1803. Mandatory: Blanks
   return gconRecord;
