I modified my report that can see the ConFirmedDate and ApproveDate in workflow history
here my SQL query.
select max(CASE WHEN APPROVALSTATUS = 40 then DATEADD(hh, 8, CREATEDDATETIME) else '' end) as [CONFRIMED DATE], MAX(CASE WHEN APPROVALSTATUS = 30 then DATEADD(hh, 8, CREATEDDATETIME) else '' end) as [APPROVED DATE] from AGSSALESTABLEWORKFLOWHISTORY where DATAAREAID = 'inf' and APPROVALSTATUS != 10 group by SALESID,CREATEDBY
and translate into X++ code.
what's wrong with this code?
select maxof(CreatedDateTime), CreatedBy from workFlowHistory group by SalesId, CreatedBy where workFlowHistory.SalesId == salesTable.SalesId; if (workFlowHistory.ApprovalStatus == VersioningDocumentState::Confirmed) { _tmpWizPSDDSDR.ConfirmedBy = workFlowHistory.ApproverName(); _tmpWizPSDDSDR.ConfirmedDate = workFlowHistory.createdDateTime; } if (workFlowHistory.ApprovalStatus == VersioningDocumentState::Approved) { _tmpWizPSDDSDR.ApproveBy = workFlowHistory.ApproverName(); _tmpWizPSDDSDR.ApproveDate = workFlowHistory.createdDateTime; }
I am getting empty value.
can you help on this.
Why this idea came up, its because i getting this problem. Please see below image with the red line box
it should be a single row. like this
how will i do it a single row ?
Thank you.
Hi metin,
Thanks for your reply. i Solve my problem .see below code.
public void getWorkflowHist(SalesId _salesId) { AGSSalesTableWorkflowHistory workFlowHistory; while select workFlowHistory order by CreatedDateTime asc where workFlowHistory.SalesId == _salesId //'INF-SO-000101502' && workFlowHistory.ApprovalStatus == VersioningDocumentState::Confirmed { _tmpWizPSDDSDR.ConfirmedBy = workFlowHistory.ApproverName(); _tmpWizPSDDSDR.ConfirmedDate = workFlowHistory.createdDateTime; select CreatedDateTime, CreatedBy from workFlowHistory where workFlowHistory.SalesId == _salesId // 'INF-SO-000101502' && workFlowHistory.ApprovalStatus == VersioningDocumentState::Approved; _tmpWizPSDDSDR.ApproveBy = workFlowHistory.ApproverName(); _tmpWizPSDDSDR.ApproveDate = workFlowHistory.createdDateTime; } }
