Illegal use of WHERE Expression in ax 2012
Hi Guys,
Can you please help me with my code.
here is the method with error. (Line 15)
public real getLastPurchasePrice(
        ItemId  _itemId)
    real                                        _Lpp;
    InventTrans                                 _inventTrans;
    InventTransOrigin                           _inventTransOrigin;
     while select sum(CostAmountPosted), sum(Qty) from _inventTrans
        group by ItemId
        where   _inventTrans.ItemId                                 == _itemId
            &&  _inventTrans.StatusReceipt                          == StatusReceipt::Purchased
            &&  _inventTrans.dataAreaId                             == 'wiz'
            &&  _inventTrans.DatePhysical                           == this.getLatest(_inventTrans.ItemId)
        join    _inventTransOrigin
        where   _inventTransOrigin.RecId                            == _inventTrans.InventTransOrigin
            &&  _inventTransOrigin.dataAreaId                       == 'wiz'
            &&  _inventTransOrigin.ReferenceCategory                == InventTransType::Purch
        _Lpp =  minOne(_inventTrans.CostAmountPosted) / minOne(_inventTrans.Qty);
    return _Lpp;
and this is the method that i call..
public DatePhysical getLatest(
    InventTrans  _item)
      DatePhysical                _datePhysical;
   // ItemId              _itemId = '0000022928';
    InventTransOrigin   _inventTransOrgin;
 while  select maxof(DatePhysical) from _inventTrans
    where       _inventTrans.ItemId                     == _item.ItemId
     join _inventTransOrgin
        where   _inventTrans.InventTransOrigin          == _inventTransOrgin.RecId
            &&  _inventTransOrgin.dataAreaId            == 'wiz'
            &&  _inventTransOrgin.ReferenceCategory     == InventTransType::Purch
        _datePhysical = _inventTrans.DatePhysical;
    return _datePhysical;
please help me..
thank you.
Related
Recommended
