version control through job
static void versionctrl(Args _args)
SysVersionControlSystem vcsSys;
SysVersionControllable controllable;
UtilElements UtilElementsLocal,parent;
TreeNode treenode;
vcsSys = versionControl.parmSysVersionControlSystem();
if(!vcsSys)
info("Version control not enabled");
return;
while select * from UtilElementsLocal
where UtilElementsLocal.recordType == UtilElementType::Table
&& UtilElementsLocal.utilLevel == global::currentAOLayer()
parent=xUtilElements::parentElement(UtilElementsLocal);
treenode=SysTreeNode::findNodeInLayer(parent.recordType, parent.name, 0, curLayer);
if(!treenode)
continue;
controllable = SysTreeNode::newTreeNode(treeNode);
if(!controllable)
continue;
if(vcsSys.allowCreate(controllable))
vcsSys.commandAdd(controllable);
I tried to do by above job, when I'm running for the first time it added the user layer tables to version control after that I did checkin to those tables manually.
Now when i tried to run the job again to add the tables, its not working correctly.
Is there any error?
Thanks in advance.
Parents Reply Children
No Data
Related
Recommended
