passing Arguments in the form level
what are the  steps and code examples to pass Argus as record to filter the records in  the other form(Ax 2012 r2)
  • Can you please make it more clear? May be use an example to explain.
  • Hello,
    Please see the following link for passing arguments,
    use the below code to filter the records,
    public class FormRun extends ObjectRun
        QueryBuildRange qr;//declare the querybuildrange object
    public void executeQuery()
        str itemId;
        itemId = element.args().parm();
       // this.query().dataSourceTable(tableNum("ItemInventory")).addRange(fieldNum(ItemInventory,ItemId)).value(itemId);
        qr = this.query().dataSourceTable(tableNum("ItemInventory")).addRange(fieldNum(ItemInventory,ItemId));
        qr.status(RangeStatus::Locked);//lock the querybuildrange object so user cannot filter the grid on other item id values
    Modify the code as per your requirement.
