Import Vendor master from excel to ax through jobs
Need to  import Contact Information like Phone number .... from excel to ax using jobs.
  • OK, you haven't told what you need? Do you already have vendors in AX? Please elaborate.
  • In reply to Kranthi:
    Hi kranthi,
    Need to import contact number and description of vendor from excel to ax .
    I have already imported vendor account, group, site, warehouse and also address . Along with this I need to import phone number into contact information(tab) of vendor master.
  • In reply to Gopinath M:
    Hi Gopinath,
    Tq for ur reply. But this is not my actual requirement. I need Phone number to be imported into Contact Information tab of Vendor. I already imported other fileds .
  • In reply to Kiran999:
    Have a look at \Classes\RetailTransactionServiceCustomer\upsertPartyLogisticsElectronicAddress
    You need to insert into LogisticsLocation, DirPartyLocation, logisticsElectronicAddress
    Hi Kranthi,
    Still I didn't get it.
    Hi Kranthi,
  • Hi, Kiran
    Please try with this job, I hope it will be useful for you.
    static void uploadVendorDetails(Args _args)
       CommaTextIO                 csvFile;
       container                   readCon;
       Dialog                      dialog;
       DialogField                 dfFileName;
       FileName                    fileName;
       VendTable                   vendTable;
       DirParty                    dirParty;
       DirPartyRecId               partyRecId;
       AccountNum                  accountNum;
       DirPartyContactInfoView     contactView;
       #File
       dialog = new Dialog("Pick the file");
       dfFileName = dialog.addField(extendedTypeStr("FilenameOpen"));
       dialog.filenameLookupFilter(['csv','*.csv']);
       if (dialog.run())
           csvFile = new CommaTextIo(dfFileName.value(), 'r');
           csvFile.inFieldDelimiter(',');
           readCon = csvFile.read();
           while(csvFile.status() == IO_Status::OK)
               if(readCon)
                   accountNum = conPeek(readCon,1);
                   vendTable = vendTable::find(conPeek(readCon,1));
                   partyRecId = vendTable.Party;
                   DirParty = DirParty::constructFromPartyRecId(partyRecId);
                   select contactView
                       where contactView.Party == vendTable.Party
                       && contactView.Type == LogisticsElectronicAddressMethodType::Phone;
                   // Phone description and Phone number
                   if ((contactView.RecId == 0) && (conPeek(readCon,2) != "")) // Please comment this condition, if not required
                       contactView.LocationName = "Phone Number"; // Phone description
                       contactView.Locator      = strLRTrim(conPeek(readCon,3)); // Phone Number
                       contactView.Type         = LogisticsElectronicAddressMethodType::Phone;
                       contactView.Party        = partyRecId;
                       contactView.IsPrimary    = NoYes::Yes;
                       dirParty.createOrUpdateContactInfo(contactView);
                   select contactView
                       && contactView.Type == LogisticsElectronicAddressMethodType::Email;
                   // Email name and emailId
                   if ((contactView.RecId == 0) && (conPeek(readCon,4) != "")) // Please comment this condition, if not required
                       contactView.LocationName = "Email"; // Email description
                       contactView.Locator      = strLRTrim(conPeek(readCon, 5)); // EmailId
                       contactView.Type         = LogisticsElectronicAddressMethodType::Email;
                   select contactView
                       && contactView.Type == LogisticsElectronicAddressMethodType::URL;
                   // URL description and URL
                   if ((contactView.RecId == 0) && (conPeek(readCon,6) != "")) // Please comment this condition, if not required
                       contactView.LocationName = "URL"; // URl Description
                       contactView.Locator      = strLRTrim(conPeek(readCon,7)); // URL
                       contactView.Type         = LogisticsElectronicAddressMethodType::URL;
                   select contactView
                       && contactView.Type == LogisticsElectronicAddressMethodType::Fax;
                   // Fax description and Fax number
                   if ((contactView.RecId == 0) && (conPeek(readCon,8) != "")) // Please comment this condition, if not required
                       contactView.LocationName = "Fax"; // Fax Description
                       contactView.Locator      = strLRTrim(conPeek(readCon,9)); // Fax description
                       contactView.Type         = LogisticsElectronicAddressMethodType::Fax;
    If it works please take your time to mark as 'This helped me'
    Thank You!
  • In reply to ThomasAlvy:
    Thanks for ur code.
Related
Recommended
