create vendor through X++
How to create vendor through X++ in Ax 2012
  • What is your AX version? Please always tag your AX version.
    Have a look at \Data Dictionary\Tables\smmBusRelTable\Methods\relation2Vendor
  • In reply to Kranthi:
    Why are you not using DIXF?
  • In reply to AdamRoue:
    Actually i want to create by job and including addresses,Contact information, financial dimensions, etc.
  • In reply to KavyaSri:
    Still the same question is valid. If you don't know how to write a job or DIXF stating point is the same.
  • Hi Kavya,
    Create a Job:
    static void createVendor(Args _args)
    VendTable vendTable;
    vendTable.AccountNum = '10001';
    vendTable.Name = 'Vendor Name';
    vendTable.insert();
    Add your required fields, whichever you would like to fill in related to vendors and execute this job.
Related
Recommended
