DictTable object not initialized error when deleting pending invoices
I am using ax 2012.
I am trying to delete the pending invoice in purchase order module and getting the following error.
The pending invoices are not visible in the AP>Enquires>History>Invoice history and Matching tables. But it is present in the VendInvoiceInfoTable.
I tried deleting it from the table I still get the same error. I can able to delete it by writing a job using dodelete(), but i want a permanent solution for this.
When I get the sourceDocumentHeader from the vendInvoiceInfo table and when I check in Accounting Distribution I can find 2 records related to it. If i delete those records I can able to delete the invoice from the front end.
Bu its not best practice to delete records from accounting distribution .
Someone can help me with any alternatives?
