GST Tax Calculation for all formats (SO,PO Confirmation & Invoice) for AX2012,AX2009
Recently many (IND Localization) requirement which needs to print Total Tax Amount in Sales order, Purchase Order Confirmation Report After India GST Update.
Along with that we need to print Tax Amount based on Tax Type (GST ,Custom Duty) & Tax components (i.e CGST, SGST ,IGST etc).
Below is the Job to get Tax amount details based on Tax Type & Tax component for a given Sales Order.
static void GSTTaxCalculation(Args _args)
    TmpTaxDocument                      tmpTax;
    PurchCalcTax                        PurchCalcTax;
    SalesTotals                         salesTotals;
    ITaxableDocument                    taxableDocument;
    ITaxDocumentComponentLineEnumerator lineEnumerator;
    ITaxDocument                        taxDocumentObject;
    real                                taxTotalGTE,taxtotal,SGST,CGST,IGST;
    ITaxDocumentMeasure                 taxMeasure;
    ITaxDocumentMeasureEnumerator       taxMeasureEnumerator;
    ITaxDocumentMeasureValue            partyTaxMeasureValue;
    int                                 i;
    salesTotals = SalesTotals::construct(SalesTable::find("SO-XXXXXX"));
    taxableDocument = TaxableDocumentObject::construct(salesTotals.parmTaxableDocumentDescriptor());
    taxDocumentObject = TaxBusinessService::calculateTax(taxableDocument);
    if (taxDocumentObject)
        taxTotalGTE = taxDocumentObject.getTotalTax().amountTransactionCurrency();
        // Calculation of Tax amount for Tax type GST and Tax component SGST
        lineEnumerator = taxDocumentObject.componentLines("GST","SGST");
        while (lineEnumerator.moveNext())
            taxMeasureEnumerator = lineEnumerator.current().measures();
            while (taxMeasureEnumerator.moveNext())
                i++;
                if (i == 3)
                    partyTaxMeasureValue = taxMeasureEnumerator.current().value();
                    SGST += partyTaxMeasureValue.amountTransactionCurrency();
                    i=0;
                    break;
        // Calculation of Tax amount for Tax type GST and Tax component CGST
        lineEnumerator = taxDocumentObject.componentLines("GST","CGST");
                i++;
                if (i == 3)
                    CGST += partyTaxMeasureValue.amountTransactionCurrency();
                    i=0;
                    break;
        // Calculation of Tax amount for Tax type GST and Tax component IGST
        lineEnumerator = taxDocumentObject.componentLines("GST","IGST");
                i++;
                if (i == 3)
                    IGST += partyTaxMeasureValue.amountTransactionCurrency();
                    i=0;
                    break;
    info( strFmt("Total GST value of sales order : %1 " , taxTotalGTE));
    if(IGST)
        info( strFmt("Line IGST value of sales order : %1 " , IGST));
    else
        info( strFmt("Line SGST value of sales order : %1 " , SGST));
        info( strFmt("Line CGST value of sales order : %1 " , CGST));
I have done modifications and posted here in this group.
Source Code Courtesy:
https://siddarthax.wordpress.com/2017/06/27/tax-amount-based-on-tax-component-for-a-sales-order-in-ax-2012-r3-after-india-gst-update/
Arunachalam MR
MS Dynamics AX Developer.
  • Thanks Arun,
    I am asking the Tax calculation for Purchase Order not for Sales Order or Purchase Invoice.
    But, you have given for Sales Order and I am thinking that you have given for AX 2012. I am requesting for Ax 2009.
    G.Rajkumar
  • In reply to Rajkumar Govindan:
    I have given for both :) For Purchase Order, u replace the sales objects into purchase. and it will work for 2009 also.
    Arun
  • In reply to Arunachalam MR:
    Finally, found the solution using this code.
    G.Rajkumar
    hello arunachalam,
    i have used same code for purchase order but system will show the error, kindly read the given bellow code and whare is bugs kindly inform.
    error is " Error executing code: PurchTotals object not initialized.
    (C)\Classes\PurchTotals\parmTaxableDocumentDescriptor
    (C)\Jobs\GSTTaxCalculation - line 17
    //SalesTotals salesTotals1;
    purchtotals purchtotals1;
    int i;
    purchtotals1 = purchtotals::construct(purchtable::find('00136646_052'));
    taxableDocument = TaxableDocumentObject::construct(purchtotals1.parmTaxableDocumentDescriptor());
    lineEnumerator = taxDocumentObject.componentLines('GST','SGST');
    i++;
    if (i == 3)
    i=0;
    break;
    lineEnumerator = taxDocumentObject.componentLines('GST','CGST');
    i++;
    if (i == 3)
    i=0;
    break;
    lineEnumerator = taxDocumentObject.componentLines('GST','IGST');
    i++;
    if (i == 3)
    i=0;
    break;
    info( strFmt('Total GST value of sales order : %1 ' , taxTotalGTE));
    if(IGST)
    info( strFmt('Line IGST value of sales order : %1 ' , IGST));
    else
    info( strFmt('Line SGST value of sales order : %1 ' , SGST));
    info( strFmt('Line CGST value of sales order : %1 ' , CGST));
  • In reply to Forever:
    we are using microsoft dynamics ax 2009
    dear can you give me code for purchase order.
    use purchTotals = PurchTotals::newPurchTable(purchTable);
    Revert back if any issues
    thanks arunachalam,
    this is the total purchase order gst display.
    we need to calculate after purchase order confirmation and item wise. We are preparing the purchase order with multiple line item with different hsn no.
    I want to print gst value in purchase order report item line wise. Please please help me.
    regards,
    vinay
    Hi Arunachalam,
    your code is very helpful. i have small query..How to get TaxRate each component wise ...help me
  • In reply to Kumar:
    just use the formulae,
    i.e., ( taxamount / base amount ) * 100
    you will get the tax rate. you can use this logic accordingly in your code.
    Hi Vinay,
    The same code only,
    dynamicsuser.net/.../490271
    just remove the summing
    actual:
    Replace with:
    CGST = partyTaxMeasureValue.amountTransactionCurrency();
    remove the summation on every loop.
    just debug the code and change accordingly in all applicable places.
    void GSTItem_TaxCalculation()
    PurchTotals purchTotals;
    int j,Line_loop;
    // SGST_Value = 0; CGST_Value = 0; IGST_Value = 0;
    purchTotals = PurchTotals::POconstruct(PurchTable::find(vendPurchOrderJour.PurchId));
    taxableDocument = TaxableDocumentObject::construct(purchTotals.parmTaxableDocumentDescriptor());
    Line_Loop = 0;
    Line_Loop++;
    j++;
    if (j == 3)
    SGST_Arr[Line_Loop] = partyTaxMeasureValue.amountTransactionCurrency();
    j=0;
    break;
    Line_Loop = 0;
    Line_Loop++;
    j++;
    if (j == 3)
    CGST_Arr[Line_Loop] = partyTaxMeasureValue.amountTransactionCurrency();
    j=0;
    break;
    Line_Loop = 0;
    Line_Loop++;
    j++;
    if (j == 3)
    IGST_Arr[Line_Loop] = partyTaxMeasureValue.amountTransactionCurrency();
    j=0;
    break;
    Array has to be declare in the classdeclaration itself.
    You have to create the below method in the PurchTotals class.
    static PurchTotals POconstruct(Common _purchTable,
    PurchUpdate _specQty = PurchUpdate::All,
    AccountOrder _sumBy = AccountOrder::None,
    ParmId _parmId = '',
    PurchId _sumPurchId = '',
    DocumentStatus _documentStatus = DocumentStatus::None)
    PurchTable purchTable;
    if (_purchTable.TableId)
    if (_purchTable.TableId == tablenum(PurchParmTable))
    purchTable = _purchTable.purchTable();
    else
    purchTable = _purchTable;
    if (_parmId == '')
    return new PurchTotals_Trans(_purchTable, _specQty);
    Else
    return null;
    Hi Forever,
    i need also tax caluclation item wise after PO confirmation . help me.
    Hi Kumar,
    U can use the above code for item wise calculation.
    G.Rajkumar
Related
Recommended
