Automatically Disable a Button
It's a weird thing that I have a button (let's name it as Button1) where its AutoDeclaration property is set to YES.  This button is place in the first form and is a MenuItem Action button where it calls a class and runs a form - second form.  In the first form I have a method that will refresh the entire form see my code below.
void refreshForm()
    common          curRec;
    curRec = AJournalTable.data();
    //Assume the condition will return true
    if(AJournalTable_ds.isOK(curRec))
        Button1.enabled(false);
    AJournalTable_ds.refresh();
    AJournalTable_ds.research(true);
    AJournalTable_ds.reread();
    AJournalTable_ds.executeQuery();
The method above is called and invoke in the second form's class.
if (_args.parmEnum() == RunChoose::Run)
    _args.caller().doRefresh();
When the second form closes, still the Button1 is enabled. Any idean from you guys?
Parents
No Data
Reply Children
No Data
Related
Recommended
