container column contents
Hello,
One of my Ax tables has a column of the data type container. The column name is xyzQuery. The content of this column is used to instantiate a runQuery as in the statement:
queryRun = new QueryRun(myTable.xyzQuery);
The statement executes without any problem. So, I'm guessing the content of this column is a query object. I can assign this column to a container like so:
container con;
con = myTable.xyzQuery;
In the debugger, I see that the container size is 1 and the datatype of the first element is blob.
I get a run time error (Wrong argument type) when I execute the statement:
info(strFmt(conPeek(con, 1)));
When I view the table in AX-AOT, the column is blank. If i View the table in SSMS, it is an unintelligible stream of bytes. So, how can I view the contents of this column?
Thanks.
Related
Recommended
