Sign function
Sign function doesn't work correctly in AX 2009 and 2012. It should returns -1 for negative numbers, 0 for zero and +1 for positive numbers. But  it gives -1 for negative and +1 for others.
Sign at Global:
static real sign(real num)
    return num >= 0 ? 1 : -1;
My correction:
static int sign(real num)
   if (num < 0)
    return -1;
   else
    return num >= 0 ? 1 : 0;
Related
Recommended
