Column size reports AX 2009.
I'm asked to change the column width of the AccountNum column on the Trial balance report in AX2009, however changing the stringsize of the AccountNum EDT from 20 to 10, will affect all other EDT's extending from this.
I can imagine that the better option would be to no longer have the LedgerAccount EDT extend from AccountNum and change the stringsize of the LedgerAccount EDT?
Still, I'm not to keen on changing the standard EDT's, so my question is if there's another better way to work around this?
Or is changing the LedgerAccount EDT as described above the way to go?
The column width property on the report itself isn't doing the trick either.
Kind regards,
Related
Recommended
