Configuration key issue
I create configuration key in ISV layer and assign to my objects.
Now I open AX in USR layer and no license import related to my configuration key
in this case I removed configuration key from properties of my objects
I can see now my objects. But is this right way to do . I can do it this way.
Can any one guide me.
Prashant
  • Configuration keys don't have to be bound to a license key.
    Which objects weren't visible? Did you verify that the configuration was enabled (System administration > Setup > System > License configuration)? Did you synchronize database after doing your changes?
Related
Recommended
