in
Dynamics User Group
Since 1995 - The Microsoft Dynamics Online User Community
Problem getting NAS to work on VISTA -> The combination of user ID and password entered is invalid
Last post 10-08-2008 22:03 by Tarek Demiati. 4 replies.
Page 1 of 1 (5 items)
Write a New Post Sort Posts: Previous Next
  • 10-08-2008 14:30
    I've installed a NAS on my laptop and each time the NAS services try to connect to the Navision server I'm getting this error message in the event viewer :
    Here's the detail of my setup :
     Version of Dynamics NAV (Client/Server) = V5
     Version of NAS = V5
     Operating Sytem = Vista
     Database type = NATIVE DB (I'm not using SQL)
     Everything is setup locally (I connect to the server via localhost 127.0.0.1) I've no problem with the Navision client server connexion, it's just that the NAS authentification which seems to cause me a problem
    BTW : the NAS service is setup to use the local user of my machine which is Administrator
    Does anybody has got a clue what could be wrong ? I've installed NAS in the past and I never encoutered this problem, does anybody has got a clue of what could be wrong ?
    Freelance Project Manager and Dynamics NAV (Navision) Developer
    E-mail : tarek.demiati@gmail.com
    Filed under:
    • Post Points: 20
  • 10-08-2008 16:27 In reply to
    Re: Problem getting NAS to work on VISTA -> The combination of user ID and password entered is invalid
    Tarek Demiati:
    This local user is also setup as a Windows-logon in NAV?
    Alexander Pallesen
    Freelance Navision Developer
    "Life is a terminal disease that You just have to learn to live with"
    • Post Points: 20
  • 10-08-2008 16:33 In reply to
    Yes, the local user is also setup as a Windows login in NAV : MYCOMPUTER\MYNAME
     However MYNAME do not have a password set, but I don't this that's a problem ....
    Filed under:
    • Post Points: 20
  • 10-08-2008 19:04 In reply to
    • TonyH
    • Top 25 Contributor
      Male
    • Joined on 10-30-2000
    • Vancouver, BC
    • Posts 570
    • Points 8,810
    • Moderator
    Have you tried giving it a password? I was playing with a completely non Nav related issue and non Nav Service last night at home, and could not get the Logon As to work for that service till I specified a password for the Username I was using. T
    • Post Points: 20
  • 10-08-2008 22:03 In reply to
    Tony, Thanks for the suggestion, you were spot on Smile Once I've set a password, stopped and restarted the NAS Service, I got another silly error message
    "You do not have permission to the session table", what I did is that I deleted the Windows login in NAV and recreated it
    After that my local Job Queue seems to work.
    You learn something new every day ...
    Filed under:
    • Post Points: 5
Copyright Dynamics User Group, 1995-2008, all rights reserved. This website and user group are independent and not affiliated with the Microsoft Corporation.
