No i'm sorry but it's the hard way.
If you have the proper license, then you can export the object as text, and do the modification in a notepad.
It can be a bit faster, as you don't have to change window all the time.
Also, are you aware of the font-window in the section designer.
Instead of going to the property-window, it's much easier to use the font-window.
Values in this change as you mark different controls.
