Report as finished error - quantity cannot be picked as 0 is available
Hi, I am running AX 2012 FP where my inventory model is FIFO with no negative inventory physical
I receive the raw item in inventory warehouse location (10) and on-hand shows that it is sitting in the correct location
that's the only part on a BoM, the production will place the finished good at location 30
automatic BoM and route consumption When I post the picklist it is correctly showing the amount in WIP.
after posting the pick-list, when I report as finished I am getting the following error.
Have anyone come across this scenario (when I allow pick negative from Inv model it is working fine).
The quantity cannot be reduced. The number of inventory transactions on order is too low because the quantity or part of it is referenced by an output order or a production order or is marked against other transactions.
  • Your BOM Consumption on the RAF parameters is set to "Always" or "flushing method" and there is no stock, it is trying to double consume as you are telling it to do this.
    Steve Weaver | Dynamics AX Solution Architect - UK
    This forum post is my own opinion.
  • In reply to AdamRoue:
    On the start stage (of production parameters for MES), i set auto-consumption to always for both pick and route
    on operation and RAF stage, i set the auto-consumption for both Pick and route to never.  With these settings, I am able to post both pick and RAF journals. However, when I post the route card, I am getting a warning message as below. Is there a reason why?
    Posting Route card Journal
    Journal has been posted.
    Posting picklist journal
    item number xxxx
    physical on-hand
    site '10' warehouse 'abc' location '1'
    1 quantity cannot be picked because '0' quantity available
    ***  Looks like it tries to post the
    pick-list journal again (while posting RAF). why?  I posted the pick-list at the start of the production operation. After that, I report as finished and then am trying to post the route card with actual hours (operational scheduling).
    Is there anything that need to consider to disable 'pick-list journal' from being posted again during the RAF stage.
    many thanks for your help.
    Hi Adam, thank you for clarifying it. You are absolutely correct. I set the 'auto consumption' to never for RAF and it worked fine. However, while posting the route card journal, it gives me a warning - I think I am double posting the pick-list during the RAF stage. please let me know where I am going wrong. thank you
  • In reply to Patrick Am:
    When are you posting the route journal - there is a posting for this on RAF and Start as well. In addition you can link BOM lines to routing operations, check your routing and BOM links as well.
    Hi Adam, I am posting route card after RAF. I set the route 'auto-consumption' to always at the Start and in the RAF, i set the auto-consumption for Route card journal to 'never'.
    Hi Adam, I have a very simple routing with 1 route for the Parent BoM and 1 for the sub-BoM.  In fact, In this example, I have one item associated to the BoM that has 1 route operation.
    While Posting picklist, i noticed that  auto-consumption is selected for the route card/journal section of the set up tab (of the picklist journal). I unchecked, but it still is giving me the error?
    You will need to step through this but by bit
    Post route at start as ALWAYS, ensure post route card is checked. Post Pick at start. The remaining status of teh order should then be RAF. Post pick journal.
    Then ensure on RAF Route and Pick are NEVER
    Is your Sub-BOM an item or is it a referenced production order? If referenced ensure this is all closed off before processing the parent.
    Hi Adam, thank you. I step through this as you from start to RAF. Everything works fine. But when I post the route, it is throwing a warning - as it tries to post the pick list again and it couldn't find quantity
    At start, I have both Pick and Route consumption as "Always"
    Then I post the Pick-list.
    Post the RAF - I set both Pick and Route consumption is "Never".
    Finally I post the Route - The route card journal is posted. However, the info log shows me that Pick-list journal couldn't be posted as there is 0 quantity.  I am not sure why AX giving me this warning.
    In the Production Control Parameters on teh Journals tab and Route card/Job Card Journal do you have "Automatic BOM Consumption" ticked?
    In the BOM on the general tab is the operation number populated?
    Is your picking end marked?
    Hi Adam, I checked the production control parameters and yes I have selected 'Automatic boM consumption' as "always" for the route card/pick journal. However, I didn't select the "Automatic BoM consumption for route card journal"
    Automatic update section, I have auto bom consumption 'always' and route consumption never for the Automatic execution; For auto-report as finished, I have auto bom consumption as 'Never' and route consumption 'Always'
    I ensured that the operation number is populated on the BoM line.
    Also I selected 'End mark' for picklist at the Start and RAF stage.
    I noticed that when I select 'end mark' for route card at the RAF stage, it posts the route card. When I don't end-mark the route, during RAF stage, the route card journal is posted.
    after that, when I try to post the route card, the route card journal is posted However, it also posts the picklist (that double my material consumption.
    Any idea if I am missing anything.
    Hi Adam. I found one thing that's quite interesting. probably I may need to do this.
    While posting the route card (after RAF), i notice in the journal line the BOM consumption is checked.  When I unchecked that, it route card journal posted without any hitch. (and it didn't post the pick-list journal again this time).   Does it mean that, i need to uncheck this option every time I post the route card journal?
    also when is the best time to post the route card. Is it after RAF or prior in general?
    many thanks
    You were at the wrong parameter Big Smile
    Journals tab and Route card/Job Card Journal "Automatic BOM Consumption" I presume this is ticked? Un tick it. This will impact on the route card journal as it will not tick BOM consumption on creation.
    Also remove the operation from the BOM line in a test.
    Hi Adam, yes. that did the trick. Thanks again for the great help.
    No problem, glad you are having fun Big Smile
    hello Adam, I noticed an issue with production orders where the material consumption costs  show almost 50% less as report as finished (with no labor/indirect) - We use FIFO.  I looked at the Production price calculation - almost all components with exception 1 component, where the realized consumption cost shows 50% less than the estimate.
    Few observations: From inventory transactions for one of the raw material item, one purchase order line show as purchased but there is no cost amount. Could that explain the drop in the running average cost?.  we brought some items through inventory movement journal and some quantity by purchase orders.   So when I sum the cost amount  and divide by total quantity there is some deviation to the running average as shown by AX as well. Perhaps running average calculation is different.
    From what I understand, the AX calculates based on  running average and then settles to receipt at the time of inventory close.
    We an raw item is received, it goes to site1-warehouse1-location 1;   The finished good is placed in Site1-WareHour1-Location2;
    I also noticed that  when the material is consumed (in the production order), the raw materials are going to location 2. So when I look at the on-hand for that item, it show two lines -- one line showing the quantity (say 50) for that location and the cost price for e.g. 100;   Another line that show the quantity deducted (per production order) but show the different location with -ive quantity available and with different cost price in that location.
    Appreciate your input. thank you
Related
