Workflow error in dynamics ax 2012 R2
When I want to create a new workflow for purchase orders in Dynamics AX 2012 R2, I receive this error message:
Workflow threw an exception for the following reason: Énumération avec '0' inconnu.
can some one help me
  • Can you tell us the exact steps that you followed?
  • In reply to Anshuman:
    I click on the link : Procurement and sourcing-->Setup->procurement and sourcing workflows.
    After I click in New button to create a new workflow based on a type
    I chose purchase order workflow and I click in "create workflow" button
    I get the error : An unexpected error has occurred while opening the workflow. See the event log on the AOS and contact your system administrator to resolve the issue.
    In the event Log I Have this error: Workflow threw an exception for the following reason: Énumération avec '0' inconnu.
    thanks for help
  • In reply to MST:
    Hi MST,
    have you find the solution to this problem, i'm also facing the same.
    Please let me know.
    Thanks & Regards
    Vijay Raj Nath
  • In reply to Vijay:
    Better compile the application once and re-generate the full CIL.
Related
