AX2012 - Copy BOM/ Route from One Company to Another Company
Can the BOM/ Route detail copy from one company to the other company? I do know the copy BOM/ Route function available but is within the company. Does AX has this function across the company?
Lee
  • I am currently wondering about the same. Hope someone knows the answer.
  • Hi,
    I don't think such a function exists accross companies, I had the same requirement and I used excel to export datas and reimport in the other company
    in Administration/Periodic/data Export/import
    Create new definition group then export the definition group and import in the new company
    BOM/Route tables list you need to export (in AX 2009):
    BOM - BOMTable - BOMVersion
    Route - RouteTable - RouteVersion
    Hope it helps
    Thomas
  • In reply to Thomas Post:
    CU7 incorporates the DIEF option and it is suggested you can copy between companies. What and how is another matter Big Smile
    Steve Weaver | Dynamics AX Solution Architect - UK
    This forum post is my own opinion.
Related
