AX 2009 Error : Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
I am getting this error from the infolog of a Batch Job Log.
The batch job runs on every day evening and most of the times it will end with out errors but some times it will ends with errors as below :
Error 1. Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Error 2. Invalid License code.
Thanks In Advance.....!
Related
