Inventory dimensions check on form
Hi Guys,
I am creating a form having Item, dimensions and dimension display button on it, but I have some troubles with dimension validations:
- I have two DS on it MyTable and InventDim connected by inner join
- write and validateWrite methods are updated so the saving of dimensions work properly
- Item field on MyTable is named ItemId which enables relation checking
- dimension display botton works OK
- I have updateDesign method run from form init (using InventDimCtrl_Frm class)
Everything works fine except for validations of dimensions when they are set as mandatory - i.e. I am able to save a line without setting siteId eventhough it is mandatory parameter.
Does anybody know what I am overlooking? Where this check must be set (I thought it is part of InventDimCtrl_Frm..?). Even some guide for would be OK.
  • Eventually I chose simpliest solution which was to put the validations on validateWrite where I call dimension validation methods on InventDim, works good...
Related
